Ok so to start this off I will give a little back ground and provide as much info as I know about my pool and equipment.
I am a new pool owner. I have never had one before. The house we bought is 30+ years old and I believe the pool is too. I do not know how many gallons the pool is but it is below ground, I have what I believe is a new sand filter (not positive on the sand part) and a robot that runs around the bottom (don't know the correct name for them) also new. The previous owner, a friend of ours, took good care of the pool with regular chemicals but I do not know how on top of water testing he did. My husband has been taking care of the pool until about a month ago when he stared a new job and has not been able to care for it. Until recently I had no idea how to work any of the equipment. I now do know how and have taken over on pool care. I will be buying a water test kit today but, I need to know what steps I should take from the point we are at. I am listing all the info I can to give you all an idea as to where I am at with the pool situation.
Now I will move on to the pool and what I am working with. We live in Las Vegas in a home that is surrounded by horse property and well it is a desert so lots of dirt no matter where we are. There have been some pretty high wind days. When I look at the pool there is a later of dust/pollen/foam. I used the net and it looks like I should be able to clear that off no problem. When I look in the water, it is mostly clear but it does have a green tint to it. I am able to see the bottom well even in the deep end (9'). The worst of it is the bottom that has a layer of dirt and I have noticed a very thin layer of algae on the walls and stairs.
So with all of that said, what are the steps I should take to clear it all out and what order should I do them in? i.e. shock water then clean dirt and algae or other way around. Any help would be great and sorry for the novel.
