I own a small pool company in Massachusetts, and the past companies I have worked for only would put antifreeze in the skimmers, not the returns. If a pool has multiple returns, I always go back and forth individualizing each return until no water comes out and then plug it up. About halfway through my closing season this year I read a lot of people putting antifreeze in their return lines just in case. After I read that I started putting a half gallon of AF in each return using a flex funnel for extra insurance. I really started to freak myself out when reading more horror stories.
I've contemplated many times going back to those pools that I didn't put AF in the return lines and putting some in as the cost/annoyance of doing so would be worth the cost of fixing a repair under concrete, but I just wanted your opinions first. I'd assume the really only issue I could have is if I didn't notice a bad o-ring on the return plug which would allow water to leak into the line with no AF as backup. Let me know what you guys think. Thanks!!
