I have had a long storied relationship with my fiberglass pool, which over the past few years I have posted and asked questions about. And now.. well things pretty much went from bad to about as bad as possible. (skip to TLDR if you aren't in the mood for a story)
A bit of backstory for fun (in case anyone is bored). A few years ago we had HEAVY rains in December in my area. During this time my shell cracked along the bottom after it noticeably tried to jump into the yard. Luckily back then my entire concrete decking was installed and held it down. But as I mentioned I ended up with a crack in the bottom (my own homemade hydro valve). But you could tell the decking raised a bit. I didn't see any of this until the spring though and it was such a great surprise. Anyhow I got quotes to fix it and ended up just doing it myself during one 90+ dry week. I did a much better job as a newb than I thought I would and saved the swim season (yay). The following spring I opened the pool and everything was great... or so I thought. I didn't clear the pipes correctly as I tried to blow them out and cap them... underwater. So of course I lost almost all of the plumbing. I then proceeded to have all of the concrete decking cut out and then I solo hand dug all the way around the pool (during the summer). I somehow managed to not die and replaced all of the pipes myself. Fast forward to this season.. considering all winter I had a giant mud pit I needed to do SOMETHING so this year wasn't gross (and my wife would swim). I couldn't afford new concrete so I got 20,000 lbs of rock and wheel barrowed it around to the back to fill the mud trench... again somehow I didn't die. Everything seemed OK at that point, the white rock didn't look bad, the wasps left and we enjoyed the summer.
And then... I woke up this morning and let my dogs out. In the darkness something didn't look right so I flipped on my light and SURPRISE! The pool decided to jump 2 feet out of it's hole (YAY)! We have had three days of straight rain, the most in a year at one time and it obviously turned my pool into a boat. As well as the fact that now trying to close the pool correctly I had dropped the water level 1 1/2 feet to just below the jets. It seems like that's ALL it took. So here I am at work half shaking my head way less devastated than I should be.
TLDR: My pool today floated two foot out of it's hole due to being dug out and all of the rain. I can't afford to get a new pool. Is it worth having it re-set and if so how much does that tend to cost? I plan on topping the pool off tonight just to see what happens... lol... I assume the back fill fell under it by I have nothing to lose.
