Waterway Poly Jets - 90° clockwise
simon_b1
8
Slovenia / Europe
Hi dear all...
My PB wants to install some of Poly Jets Waterway Poly Jets rotated 90° (plumbing space issues)...
We will have a 3HP pump + 2HP blower installed to support 10 of these jets.
According to his reply, "since we are using blower, there should be no issues with air flow"...
What is your opinion on that?
mas985
13,856
Pleasanton, CA
Rotating shouldn't be an issue but what size orifice are you getting? Even 5/16" jets require 10 GPM each which is a 100 GPM total. Depending on the plumbing setup, the pump may not be able to deliver than much flow rate.
simon_b1
8
Slovenia / Europe
Hi, thank you for your feedback
Well plumbing:
- return 2,5""
- suction: 2+2,5""
70 feet return line (with all the elbows and tees losses on the return side calculated)
mas985
13,856
Pleasanton, CA
What size are the jet orifices?
Does the water going to the jets also travel through a filter and heater?
simon_b1
8
Slovenia / Europe
If I remember correctly (sorry, not at home to check it), but I think there are two versions included:
210-6040 -- adjustable ones
210-6100 -- regular ones
No heater, no filter - water from the pump directly to the jets
mas985
13,856
Pleasanton, CA
I believe these are 10 GPM jets. 100 GPM total.
What did you mean by suction: 2+2,5"? If there are two MD covers, those are connected by a short line with a single line back to the pad. The short line between the covers should really be 3" but the line back to the pad is ok at 2.5".
simon_b1
8
Slovenia / Europe
Hi, wow, thank you for all the support and feedbacks
There are two separate lines from the drains (1st one is 2,5" and the 2nd one is 2"), they will go separately all the way to the pump --> beside the pump they will be attached onto a T-coupling --> into 2" (if I remember correctly, the pump has 2" threads)
- please don't ask me why different sizes - obviously "optimisation momentum" from PB side or maybe any other reason I do not know currently
mas985
13,856
Pleasanton, CA
With a separate jet pump, a second loop is usually plumbed in to take care of heating and filtering of the spa.
simon_b1
8
Slovenia / Europe
Just a quick bginfo for you:
- as in main drawing there was planned to have 2x2" from 2MDs into one 3" pipe
- due to some electrical lines and old house plumbing space issues, he could only squeeze max 1x2.5" and 1x2" through the holes, so the PB decided to use the t-coupling just before the pump
- since this (spill over) spa is part of an bigger pool, there is a special return in this spa, that will supply it with filtered hot water --> spill over into main pool
Let us hope, he knows what he's doing ;)
mas985
13,856
Pleasanton, CA
That is not to code and can be very dangerous. The reason MDs are tied together at the MD location is so that if someone blocks one of the drains with their body they won't remain stuck. If you take the lines individually back to the pad, then someone can get stuck on one of the main drains. It would be better to tie the MDs together with 3" pipe and then use only one 2.5" pipe back to the pad.
simon_b1
8
Slovenia / Europe
will talk to him
thanks
