- Jul 18, 2020
- 24
- Plaster
- Hayward Aqua Rite (T-3)
Hi,
I was wondering if there is a proper product like that, but made for stand alone (3HP) pool pumps running on 220V.
www.hydrocheckproducts.com
I've found a moisture sensor from Pentair but that's supposed to go with an automation system and I guess other automation systems have such option too, but I run a single pump without any automation only.
www.pentair.com
Thanks
WaterWatcher Leak Detector Alarm | HydroCheck
Additional InformationThe HydroCheck WaterWatcher is an innovative, leak-detecting device that is designed to stop leaks at the source. When water is detected, the WaterWatcher turns off the appliance that is causing the leak and sounds an alarm. Capable of detecting even the smallest, purest...
Pentair Pentek® VFD-WS Pump Shut Down Moisture Sensor w/ 15' Cable
For reliable water supply flowing throughout your home, lawn and garden insist on Pentair water supply pumps. View all products here.
Thanks
