Waterline Tile - Did I Make a Bad Choice?
racdash
2
Maryland
I am new to TFP. And hoping someone can help. We inherited a pool this summer and it has proven to be a bit of a debacle. We are having to fix the plumbing and re-plaster as it had a leak. The pool shape was NOT shape I would have picked (roman shaped). We are replacing the hardscaping/coping (we had to do this) and chose all the same to try to minimize the shape. We chose Diamond Brite French Gray plaster. I have never chosen pool tile and wanted to choose a tile that would help up minimize the shape so I chose a dark blue grey to hopefully blend with the water. BUT, now i am thinking it will stick out way too much and I should have matched the hardscape with a lighter grey or white? So, here is the question - am I way overthinking it? When choosing tile you want to blend should you match the coping or the water color? Thank you for you help!
Desert Dog
343
Alpine, Ca
Maybe I can help you get more eyes on your thread/question. Colors are such a personal choice, its a hard question to answer. With a Roman shaped pool, I'm sure you want something not to crazy and eye popping. Perhaps posting a pic of your coping and anything else that's around the pool will help. Personally, I like the plaster/tile color combo you have picked.
Nikilyn
1,127
Gilbert, AZ
Pentair Intellichlor IC-40
That tile is gorgeous 😍. I like the white also but when I see white tile I like it with a lighter blue water. For the pebble you picked I think the darker is better.
