I currently have a Hayward Super II Pump (I think - label long gone) being pushed by a A.O. Smith Century Centurion motor (Model: B128, Type: CX, FR: U56J, HP: 1.0, HZ:60 ,RPM: 3450 , Volts: 230/115, Amps: 6.0/12.0). I haven't run the waterfall in probably 3 years and the motor on the pump needs replacing. Saw the one below and want your opinions. We were thinking the old 1 HP was pushing too much water through the waterfall anyway and one reason I was looking at the 3/4 HP.
Bluffton B1321 0.75 HP Up Rated Single Speed Threaded Replacement Pool Motor
If this isn't a viable alternative, is there a cheap motor you suggest that would fit?
