Nadel2014
4
Savannah, GA
Fiberglass
Jandy Aquapure 700
Hello I have a Jandy AquaPure with IAquaLink. Three days ago I started getting an error message reading on my interface app showing water temp SHORT and my salt water generator stopped producing chlorine. I have chlorine production set to 75% in the app but it reads 00% on the panel. By all indications the salt cell is on and it has FLOW, it’s just not producing chlorine. I am not getting any service codes on the panel. We ordered a new water temp sensor for the heat pump and replaced it yesterday but that did not fix our issue. It still reading SHORT.
These are the things we have tried:
Replacing water temp sensor on the heat pump.
Cleaned the salt cell and the salt cell air/water/flow sensor.
Reset the web interface.
Switched the air and water wires (still read short)
Reset the system by turning off main power and cycling it back on.
Next step, I’m thinking, is to replace the air/temp/flow sensor on the AquaPure.
Is there anything I’m missing? I really don’t want to have to replace the circuit board.
ajw22
39,878
Northern NJ
Pentair Intellichlor IC-60
Remove the temp sensor buss from the board and see if problem persists. Remove the entire buss, not just remove the wires from it.
Also, have you tried clearing the memory?
Reset is done through the software (panel in house). MENU/HELP / SYSTEM SETUP / CLEAR MEMORY. Then follow on screen directions. Note: Make note of your settings, labels, programs, etc. Clearing memory resets your unit to the same state as when it came out of the box.
Nadel2014
4
Savannah, GA
Fiberglass
Jandy Aquapure 700
Yes, I forgot to mention that I did clear the memory and when it came back up it’s hill showed SHORT for water temp. We will try removing the buss. Thank you.
Nadel2014
4
Savannah, GA
Fiberglass
Jandy Aquapure 700
Our issue has been resolved thanks to a gentleman on a FB group I am in. Here is the information:
“ If the main screen display on the app shows “short” on the water temperature- the temp probe that is in the water return line is what needs replaced. Should be a simple temp probe with a stainless steel screw clamp on it. It is a 2 wire sensor that goes into the far right top green plug in the RS board. The aqualink RS system uses that temperature probe for water temp - not the one in the heat pump or the sensor in the salt cell.”
