Hello,
I noticed that the water is coming out of waste line when pump is on filter mode. I order a new key assembly (link below) and replaced it but it didn't fix the problem.
Do I need to replace the whole top mount?
www.poolzoom.com
Thank you
OEM Key Cover Handle Assembly
Key, Cover and Handle Assembly for Hayward SP-714 Valve. Does not include Cover O-ring SPX0714L, must be purchased separately. This part fixes the following symptoms: Water leaking out of backwash port.
Thank you
