Water softner salt?
Amy Adkins
Active member
Jun 8, 2019
25
Ohio
Are we able to add water softner salt to a above ground pool that doesn't have a salt generator? If so, is there a kit that will test the salt levels? And, how much salt do we use?
mknauss
29,158
Laughlin, NV
A Taylor K1766 salinity test kit will measure salt levels.
You can add salt to any pool. Try adding 1500 ppm to the pool. Use PoolMath
Not sure you need to test for it, but that is up to you.
Reactions: Amy Adkins
