Water not heating enough through solar panels
imranmoin
7
San Jose / California
The water in my 20K gallon pool is not heating enough through the solar panels. I have 9 solar panels and the pump runs for about 6 hours every day. I get plenty of sun during the day. I have a 1 horsepower fixed speed pump, and I read somewhere that it might not be pumping enough water up the solar panels. Do you think upgrading to a 3 horsepower variable speed pump will result in heating the water more? Also, would you recommend Intellipro or Intelliflo pump?
cowboycasey
9,034
Southern OK
CircuPool SJ-40
If you run your pump 10 hours a day would it heat it? To get more heat you would run the pump longer or get more panels...
I think you are trying to go to a VS pump to save money on power but the solar panels require a certain flow to work.. The VS would save you money if you could push the same amount of water at 1800 rpm instead of 3800 rpm like now...
Reactions: imranmoin
mas985
15,394
Pleasanton, CA
What size are the panels?
What is the pump make/model?
What is the height of the panels relative to the pump?
What is the filter pressure without solar running and with solar running?
