Water Loss
Jcsmith9
78
Birmingham/Alabama
Hey guys just had a brand new liner installed with a new hydrostatic relief valve also replaced in the main drain at the bottom of the pool. This is an inground vinyl liner pool. Filled the pool yesterday half way up the skimmer and woke up this morning and the water level has dropped more than 3 inches. Anybody have any ideas as to what could be going on? Oh also to mention I had an entire skim coat of the bottom floor of vermiculite .
JoyfulNoise
Platinum Supporter
May 23, 2015
21,408
Pentair Intellichlor IC-60
You can leave the water in there and see where it stops. If it’s new liner then get the company that did the work to come back and fix the issue. Hopefully not a tear anywhere in the new liner. My guess would be something wasn’t sealed properly - skimmer, returns or bottom drain. Where the water settles will tell you where the leak is.
JoyfulNoise
Platinum Supporter
May 23, 2015
21,408
Vermiculite is not waterproof; in fact, it is intended to allow ground water to flow through it as needed. So any water loss is simply being absorbed into the surrounding earth around the pool.
Reactions: Jcsmith9
Jcsmith9
78
Birmingham/Alabama
That’s what I will do then. Thank you so much for the feedback.
Reactions: Casey
JoyfulNoise
Platinum Supporter
May 23, 2015
21,408
Got it. I’m looking out there now and it looks like the water is just below the white skimmer plate. I will keep checking to see if it’s leaking but as of now I don’t see it dropping further. Wonder what this means?
There are gremlins hiding in the bottom of the pool and they wait for you to not be looking and then spit water out of the pool .... OR .... the skimmer is leaking.
I dunno, I'm kinda partial to the gremlin theory ...
JoyfulNoise
Platinum Supporter
May 23, 2015
21,408
haha! What would it mean if the skimmer was leaking? Is that an easy fix?
It's likely the face plate or the rubber gasket behind it wasn't sealed up properly when they installed the liner. I'd ask the pool company that did the work to come back and check the installation. It shouldn't be hard to fix ...
JoyfulNoise
Platinum Supporter
May 23, 2015
21,408
I don’t think one screw would be a big deal but if they are all loose then that’s not good. Unfortunately I’m not a vinyl liner pool owner, so not exactly familiar with the limits of a vinyl skimmer.
Perhaps @Leebo or at @Casey might have a better idea.
