Happy new year TFP! I can't wait for the weather to warm up so I can jump into my resurfaced pool! I have to still run the pump more than usual since its still curing (It was done on 12/5 and they did an additional acid wash on 12/28) but I want to at least have it all planned out to get it handled ASAP. If I estimate the rate of water loss I would say it takes about 2 weeks for me to see the water go down below the middle of the skimmer after I fill it up.
Here are my current issues:
S1. I can just buy some pool putty and apply it for the skimmer leaks right? Seems to be the easiest thing.
S2. I replaced the grease caps on my jandy valves a few months ago and that helped a lot when the air leak was worse. A small amount of water squirts out of the pool pump lid most of the times I turn off the pump. Part of it is the lid for suresince unless I tighten as hard as I can without tools I get more bubbles than I have now. Still have some even after relubing and really being careful with it today so not really sure what else it could be.
S3+S4. Sigh... cutting it out is the only option right? My father-in-law who would likely be helping me with the plumbing is simultaneously aware of pressure side leaks being un-patchable while also goading me to try Flexseal. Not sure why I need to do something in futility to appease him but thats life! How much would I need to swap out? Since I don't use the chlorinator should I remove it entirely? Obviously want to do as little mucking around as possible. My inlaw is good with pvc fittings but I would love suggestions about unions and other things he would cheap out on if I give him a chance. I guess I would be willing to do more work to have as few fittings as possible.
My filter's PSI is getting high quickly lately but with the resurfacing its kind of a useless metric at the moment.
I do my research well but I always get nervous when it comes to actually taking the plunge. Always appreciate getting your lovely opinions!
- Gap between skimmer and concrete
- Fair amount of air bubbles coming from the return jets
- Leak at the PVC fitting on the pressure side of my pump (I would say it only takes a few seconds to get a drops worth to leak out)
- Leak (at least its moist but never enough for a drop of water to happen in my presence) at my stupid chlorinator I never use. Also one I literally just felt (cant see) on the connector to my filter. The glue or whatever on it is flaky.
