Water Level Dropping Faster Than Normal
CincyDools
Active member
May 18, 2017
43
Cincinnati, Ohio
It seems like our water level is dropping faster than usual. We have a 20x40 Lazy L (33,000 gallons). We added a heater this Spring. So I am wondering if water is evaporating more since the pool temperature is being held at 90 degrees. Is that possible or should I be worrying about a slow leak?
Newdude
5,447
NY
If you didn't get a solar cover too, than the likely answer is yes it is evaporation. 70% of your heat loss comes from evaporation. If the pool is warmer than last year, it will average more loss overnight. Another factor in evaporation is square footage. The more surface area you have, the more you can lose to evaporation. With an 'L' pool you have crazy surface area.
CincyDools
Active member
May 18, 2017
43
Cincinnati, Ohio
Thanks. Yes, I have a lot of surface area. And the Lazy L makes a solar cover a pain to work with so I have never have used one. And because we have 8 grand kids, we use the pool pretty much daily so I don't want to have to put it on and take it off. So I guess I will need to live with the evaporation. Thanks for the reply.
