water just doesn't want to clear up
nabril15
340
Miami, FL
#1
Good morning
I have been testing my water daily since it has a cloudiness that just won't go away.
I brush and clean leaves daily, and with every brush I lift up a noticeable amount of algae - specially from the deep end and flat surfaces (stairs and bench); however, I see algae in that small quantity all throughout. This morning's numbers:
fc 8, ph 7.5, CYA 40, TA 80, CH 275.
I know that I'm probably getting close to having to SLAM again, but I've opted for trying to keep my FC at the top of the range of the CYA/FC chart.
It's been windier than normal in the last few days, so I see a thin film of something on the water as it accumulates in the skimmer; I also see it around the shallow end steps.
Do I lower my ph to 7.2 and SLAM? Or do I keep brushing (I will do so regardless) and keep FC high at the range? This doesn't seem to be working though.
Thank you
see_feel
28
Arlington, Texas
#2
Good morning
Thank you
If you are seeing algae then all the maintaining FC won't help, you'll just endlessly spend money on bleach. I would advise to start slamming now to get the mess cleaned up. Keep brushing and once you pass the OCLT you are out of the woods.
nabril15
340
Miami, FL
#4
And so my slam continues.
Is it "better" to run the pump on skimmer, main drain, or suction cleaner during the slam? Using the suction cleaner obviously will pick up floor dirt and algae, but suctioning through the main drain or the skimmer will move more water, no?
Also, is it ok to double check the cya during the slam? I know that nothing shoud change it from the initial pre-slam reading, but just to double check it perhaps???
nabril15
340
Miami, FL
#7
For 2 days, the ocl test passed fine with 0 loss, and the water looks much clearer; I didn't check CC - I admit that I forgot about that. Today, fc was 12, from a slam level of 16. Do I continue with the slam and obviously test cc and oclt tomorrow?
I've also noticed that the water has floating and yellow/brownish suds floating. It has been windy all week, so I obviously know that a lot of things are flying around. And it's not sunblock or anything else. When I look in the skimmer (see 2nd picture) , I see a floating layer of whiteish gook, and I can see the water rushing in underneath.
What could that be? And how do I get rid of it?
nabril15
340
Miami, FL
#12
good morning
I finished my SLAM from 2 weeks ago by meeting all 3 criteria; the pool looks crystal clear and those floating suds are gone (whatever they were). So, I relaxed a couple of days with the testing since I know that my FC will slowly come down from the slam level of 16, but I continued to brush. Today, I decided to test after my landscaper blew grass everywhere, and here are the numbers: FC 9, ph 7.5, ta 80, and CYA 40. As I brushed this morning, in addition to grass clippings, I also saw a bit of algae and dust blown by the gardener. Do I take my FC to the upper level of the FC/CYA chart?
nabril15
340
Miami, FL
#16
From previous posts and daily tests, I learned that chlorine is consumed daily. So as of the last slam, I've been having to add a bit here and there to try to keep my fc at 10. No biggie.
I have an inline chlorinator, so I wonder if using pucks would help me maintain that 10 on its own kind of thing. Sure, the pucks add a bit of cya, but it's a small amount.
What do you think?
JohnT
Admin
9,460
SW Indiana
#17
What do you think?
It's not a small amount. It's a lot.
