Water just added, water temp above 60, now what?
cteal
64
Birmingham, AL
Hello out there!
We are about finished adding the water and I wanted to be prepared. I fill be doing the TFP method. I know I need to add the CYA, per the sock method. I had previously been instructed to add bleach after that and then when water hit 60 degrees add the salt. Well that was when it was colder out. The water is around 66 degrees. Should I skip the bleach and go straight to the salt?
Jimrahbe
15,768
Bedford, TX
C,
Salt cells are designed to "maintain" your chlorine level... The reason you add bleach is just to quickly bring up the FC level where you want to be. You can skip the bleach, it will just take the SWCG longer to get the amount of FC you need in your pool...
Make sure you let the salt dissolved for about 24 hours before you turn on your salt cell..
Thanks for posting,
Richard320
22,069
San Dimas, CA (LA County)
Get the chemistry all dialed in using bleach for chlorine. Once you have all the parameters in a good space and the salt is dissolved, turn the SWG on. It'll take a little trial-and-error to find the right pump time and SWG percentage to maintain the FC; you don't need to complicate things by juggling everything at once.
rmturner54
555
Waxahachie, Tx.
Here is what i did. Keep using bleach to maintain fc, added salt.
Added cya to correct level. Once salt dissolved turn on swg. I started a 50%. Monitored fc daily and adjusted swg and pump run time as required.
