Water is not clear but numbers are good
koffey
109
Toronto
Hey folks,
I'm super confused. I came out of SLAM weeks ago and everything was great. I've noticed that my water isn't 100% clear anymore and I've noticed some what I suspect is algae growth. I vacuum the pool every second day and my numbers are what I think spot on.
Any advice?
It's a 7000g vinyl
cya 45
fc 9
ph 7.6
ta 90
cc 0
ch 100
Pool has been uncovered for about 4 hours now and I just tested the water. I stopped running the pump over night, but it runs for a solid 10-12hrs a day. Going to do a backwash and rinse right now but I'm lost.
koffey
109
Toronto
Hmmm, just found a similar thread that must have missed before posting... So raise FC to slam levels.
cowboycasey
8,648
Southern OK
CircuPool SJ-40
It could be a couple things...
Is the cover on for the 2 days between brushing or do you take it off some? (not that it matters, i have left mine on for 2 weeks before...)
How well is your circulation in the pool, do you think there are spots that do not see much chlorine like in the corners of the pool... I built a 90 degree 1.5 inch eye to get my water moving all the way around the pool., you can kind of see it on the wall in these picks..
Sometimes I have noticed mine is also just not as clear as I know it can be.. Just raise it to SLAM level for 24 to 48 hours and everything is great in the world again...
One thing I noticed, There is not a 45 CYA, it is 40 or 50... :)
Reactions: koffey
koffey
109
Toronto
50 it is and thanks for the tip, I started swirling the chlorine after dumping it in and I always remove the cover to clean it. I'll leave the cover on if it's a day that I won't be in the pool.
DorsalSpine
863
Columbus, Ohio
Check your filter pressure as well. Make sure you don't need to clean anything. My water started to look hazy right before a pool party. We were so busy working on the landscaping getting ready that I wasn't watching the filter as closely as I should have been. My numbers were good but the water was hazy even at SLAM levels. The filter needed cleaned. I pulled it apart, did a deep clean and the water cleared up over night. Everybody thought the pool looked great.
Reactions: koffey
