Water Chemistry Coming off the charts when pool level water elevates
anre5180
15
Miami, FL
Hello, team of fellow pool lovers:
I am having an interesting situation where when it rains heavily here in South Florida and the pool water level raises my chemistry comes off the chart. and I found myself having to balance again. Ughhh... makes no sense as I shouldn't be losing Salt levels or CH or CYA. Under normal circumstances, I adjust my FCL, PH, and ALY depending upon what's going on with pool activities. Maybe a bit CYA due to warm pool temps (close to 90 due to South Florida sun and heat), luckily not a lot of crosswind at pool location.
I suspected a leak and I bought a test kit and grab my scuba tank and went all over the main drain, pool light, return jets, etc.
Found nothing... but I noticed as I pay closer attention there is a crack above normal water levels in the tile that I suspect I am losing water (and chemistry) when it rains a lot. what do you guys recommend to use to repair that?
I can't think of other ways I would be losing chemistry only when the water level raises... note: the pool has never overflowed (luckily). So far just a bit higher than skimmer top-level (during sustained rain over without a break)
Pool Math Logs
anre5180
15
Miami, FL
Is the sample mostly rainwater?
the pictures are my actual pool water (it's crystal clear and hard to see, but it's there... lol ;)) ... but yes... I rarely have to top off via hose (city water) ... it rains often down here.
I am not draining/topping off constantly since the skimmer has a good 6" opening allowing me to keep water levels within that opening and hold for a few days without rain without having the need to top-off.
mknauss
43,737
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Your Pool math logs look OK -- realize the ColorQ is at best accurate for low FC and pH. Other parameters are not very accurate from that kit. You should get a proper test kit.
poolnoobgrandma
663
Seminole, FL
Pool Math Logs
You don't have an autodrain that no one told you about, do you? We are in west central Florida, and we don't have an autodrain. Without draining during or before a storm, our pool has definitely overflowed a few times.
cowboycasey
8,567
Southern OK
CircuPool SJ-40
Sounds like you have an auto drain and every time it rains you are losing water.. Depending on where you live in FL you can get 6 inches of rain a month... If your pool has never overflowed you have drain somewhere...
At least 1 or 2 times a month you should check everything and add as needed :)
Reactions: poolnoobgrandma
JamesW
27,188
The point of my question is if the sample is from the top of the pool where it is mostly rainwater or is the sample a well mixed water sample from deeper in the water?
anre5180
15
Miami, FL
oh... my apologies. the sample I test from is once my PoolMAX (cleaner side vacuum) finished in the morning. I am awake at that point and I dunk my sample bottle down to the return jet and fill up there. so the pool is well mixed after 4h of being at 3200 RPMs.
anre5180
15
Miami, FL
I am a recent pool owner (less than one 1year) ... what does an auto-drain look like? I have looked around the pool equipment and pool deck and I see no noticeable indications that pool is overflowing somewhere...
mind you the level seldomly goes above the skimmer 6" window... and when it does it never makes it to the top of the deck where I can see an actual overflow
forgive my lack of knowledge
JamesW
27,188
Can you show a picture in the skimmer?
It might leak out at the top of the skimmer where the extension collar connects.
anre5180
15
Miami, FL
Recent pool owner (less than 1y) here so apologies for the lack of knowledge. what does it look like? I only drained 1 time but that's understandable chemistry will be off... but the symptom of chemistry going out of whack then pool gets too much water... i can't explain it.
perhaps is psychological of me trying to find out an excuse and culprit on that crack I saw on the tile. I do know for sure that while water remains below that crack level... i don't have such swings in water chemistry
if the windows of my skimmer is 6" my ideal water level is around mid skimmer... so when water remains between 2" to 4" on that 6" window my chemistry is good.
the challenge comes when water goes above that 4" almost to the top of skimmer window and even some time covering the whole skimmer window but without top deck overflowing ... then the water level is exposed to that crack I send pic of... i am not sure how else to explain the swings in chemistry
anre5180
15
Miami, FL
where would be that extension collar connection? if you could show it on a diagram and can better understand where to look and take a pic from. would you mind please perhaps circle it on red where the possible leaks could be ?
anre5180
15
Miami, FL
do you have a test kit you would please recommend ...?
ColorQ and AquaChek 7-way pool Test strips (as backup and quick-every-other-day check) have been my methods so far
JamesW
27,188
The main skimmer body should be a single solid piece.
Then, the skimmer lid assembly (Part number 2) goes on top of that.
If the lid assembly needs to be higher, an extension collar is used.
You should see a seam at about the level of the water about where I put the red line.
anre5180
15
Miami, FL
Thank you for that clarification. attach are some pics... i don't think I have an extension based on where you drew the red line...seems like a full piece
I can't take better pics without dunking my phone in the water o_O
mknauss
43,737
Laughlin, NV
Fiberglass
You need a proper test kit. I suggest the TF-100 or Taylor K2006C. A proper test kit is needed to get the accurate water chemistry results needed to follow the TFP protocols.
anre5180
15
Miami, FL
This seam will leak if the water gets to this level.
ahhh... interesting... ok... I will get my little mirrors that came with the leak kit and inspect better underneath that lip...(can I use the putty in the kit to seal if I see a culprit?) for sure water has gotten to that level (black arrow) but never past this red line otherwise I would've seen top-deck overflow and I haven't. the kitchen windows overlook the pool and skimmer so even during storms and heavy rain I have full visibility into the pool and water levels.
JamesW
27,188
Here, you can see the skimmer without the extension or the lid assembly.
Here, you can see the extension inserted into the main skimmer.
The extension slips inside the main skimmer by an inch or two and is not sealed.
