Hi All,
I am a first year pool owner and noticing the change in water balance as the water temps cool off, even in Florida.
Below is my current test results from this morning using K-2006C/K-1766.
As you can see, the water is well balanced on the CSI, but Ph is a little high. I normally catch it at about 7.9/8.0 and lower to 7.5/7.6. With this current balance I am only adding a little acid about twice a week.
But, if I treat down to 7.5/7.6 Ph, my CSI will little lower than - .30...but only for about 1 day before it moves up a bit.
I think I should bump up the Calcium to 400 to give me a little room on the CSI to treat the Ph down to 7.5/7.6.
I go to the pool store once a month for testing because of my pool warranty. I told them my plan and they talked me out of buying the Calcium...weird. They just though my Calcium levels were good to go for a Florida pool. But, they don’t pay much attention to CSI anyway. And, they were getting a 100 TA, when I know for certain I am right at 70 TA.
So, finally my question. Bringing up my Calcium Hardness to 400 is a good move, correct? Even in Florida.
Thanks
Water Temp 82
Chlorine: 6
Ph 7.9
Calcium 325
TA 70
CYA 70
Salt 3400
Thanks
Water Temp 82
Chlorine: 6
Ph 7.9
Calcium 325
TA 70
CYA 70
Salt 3400
