Water @52 degrees, is the swg still making chlorine?
Titan7
663
Fullerton, CA
At what point do I kno if it's too cold, I did notice the system is showing salt PPM dropped. I read that's caused by cold water. Can I assume if it's maintaining chlorine levels it's still working. Just did not know if there is a point to shut it off and manually add chlorine.
Thx.
Jimrahbe
15,910
Bedford, TX
Titan,
Looking at your manual it says that when the water temperature gets below 51 degrees, chlorine production stops and a service code of "Lo" shows up indicting a low temperature cut off.
