VSP Comm Error - Hayward EcoStar & Pro Logic
m_cannon
1
Manasquan
#1
I cannot get my Hayward Pro Logic board to communicate with my Hayward Ecostar VSP pump. The pump says "Comm Bus Offline" and the Pro Logic says "VSP Comm Error". I followed the instructions to the T and can't get it to work. I even tried running different wires between the 7/2 & 8/3. The Filter Bus Address is set to "Filter". Any suggestions would be greatly appreciated as I'm out of ideas!
Matt
pooldv
Platinum Supporter
24,993
DFW, TX
#2
Welcome to TFP!
My only suggestion here is to call Hayward for some help on this one.
rcy
345
Burlington, ON, Canada
#3
Don't know if these will help you or not. I know the Tri-Star technical guide helped me set my Tri-Star VS up in relay mode to work with my Jandy PDA controls. Good Luck.
http://www.haywardflowcontrol.com/pdf/manuals/EcoStarDiagnostics.pdf Page 10 shows how to hook up to Pro Logic. You must have software version 2.65 or higher.
https://www.hayward-pool.ca/pdf/manuals/2015-EcoStar-Troubleshooting-Guidev4.pdf
https://www.totallyhayward.com/techservices/attachments/Technical%20Service%20Bulletin%20PFC%20Hi%20error%20code.pdf
