VSF pump losing communication with intellicenter motherboard
Somertime527
In The Industry
Mar 28, 2020
5
Millville, NJ
Have all wiring correct.. Have yellow and green communication wired to J5 Comm port Schedule is set to run on 3 schedules. Morning, day time and night time with no overlapping
I have n problem turning pump on with intellicenter touch screen.. Come to check on automation the following day and have an alert that VSF pump lost communication but I can still turn it right back on please help
setsailsoon
2,548
Stuart/FL
S,
Welcome to TFP! Pentair makes great automation equipment. Please do add the details in your signature that Marty requested. Here's how. While you do that I'll ping one of our automation experts @Jimrahbe I'm sure he'll be able to help you solve.
Chris
Jimrahbe
16,926
Bedford, TX
527,
My guess is that you have the 240 VAC, that powers the IntelliFlo, wired through the Pump/Filter relay. As soon as the relay shuts off, the power goes away and you then get the communication error..
The IntelliFlo and IntelliCenter should have constant AC power..
JamesW
18,419
Does the pump get continuous power?
It should be powered directly from the breaker.
If it's powered from the load side of the relay, it can lose power and lose communication with the automation.
Somertime527
In The Industry
Mar 28, 2020
5
Millville, NJ
527,
Thanks for the input, just confused
JamesW
18,419
Power directly from the breaker or the Line side of the relay so that the pump stays powered.
The SWG gets powered from the Load side of the relay.
Reactions: MyAZPool
