Hi all, over the winter my vinyl liner has gotten seriously stained. This has happened before, and citric acid cleans it up. So I put in citric acid about 2 weeks ago, and by the next day the stains were gone, so I happily went about my business.
Here is where things went awry.
Several days later I noticed a bunch of brown/green sediment on the bottom of the pool, I assumed it was algae, and so I brushed it and shocked the pool with bleach. And I did a water chemistry test and found the PH and TA were very low, so i put in 10 pounds of baking soda. I've since read that shocking and raising PH after using citric acid is problematic, but here we are. This turned the pool water a nuclear colored green/brown. But I had to leave out of town on business for a week, so I left it.
Now, the water is pretty clear, but the liner is completely stained again.
Here are my latest water chemistry results:
I know my CYA is too high, i have a sump pump on order so i can drain water and refill. I'm also planning on switching to SWG in the next month or so to avoid puck-related CYA problems.
pool capacity - 20,000 gallons
Water temp - 64
FC - 3.5
CC - 0
PH - 7.2
TA - 60
CYA > 100
I have available some Natural Chemistry Metal Free, Cu-Lator metal eliminator, Jacks Magic Magenta Stuff, polyquat 60, and more citric acid. I have not added any of this at this point.
So, can you advise of the proper procedure to get rid of these stains?
Thank you!
Water temp - 64
FC - 3.5
CC - 0
PH - 7.2
TA - 60
CYA > 100
Thank you!
