Hello all,
I have a 20'x40' (33,000 gallons) in ground pool that had the liner replaced about 10 years ago (before I owned pool). It is now starting to slip in 2 places. I'm assuming the only way to fix is to drain water and pull up. Since I'm not wild about doing that in the middle of the season, I'm wondering if drilling a hole where the white liner lip meets the plastic backer and use stainless steel screws as a way to make sure it doesn't get any worse. Thoughts? Thanks for your advice.
