VGreen 165 control panel doesn't react - looking for VLink unit
JohnnyBe
11
Curaçao
Hi,
I have a VGreen 165 pump that works fine.
A while ago the control panel (on top) was giving some issues, I had to press the selected buttons a couple of times before it worked.
Recently the control panel doesn't react at all.
It does follow the program and pump function is fine.
I opened the top and everything is clean and dry, my assumption is that the control panel may be broken.
I am looking for information on where to buy this part (if available) , I got one response from a reseller and it was a quote for a complete new pump (which is a bit too much I think).
I also read about a V-Link option, that unit can be attached to the pump, I can then hook up to my WIFI and control the unit with the App on my phone.
That seems also an option assuming I would be able to bypass the failing control panel.
But I haven't found a supplier for the VLink yet.
Hope that someone can help me ?
- Can the control panel (on top of the pump) be purchased separately somewhere?
- Does anyone have information where I could buy the V-link unit?
Thanks
John
JamesW
23,247
Has the #1 DIP switch always been on?
Does that match the manual for how it should be set?
What voltage are you getting when measuring from L1 to L2?
MSchutzer
61
Redwood City, Ca
DIP switch 1 just turns the 12v on and off on pin 1 of the RS485 connection and doesn’t affect the pump configuration itself. It’s on by default as I have the same pump.
Reactions: JamesW
JohnnyBe
11
Curaçao
Just checked , voltage is 235 V on the L1 and L2 , that is the correct current here (Curacao).
No changes to DIP switch, always like that.
Is there anywhere an option to purchase the control panel that is on top ?
It has a flat cable that goes through the cover under the buttons and connects to the rest of the motor.
Seems glued to the cover so I was hoping this is a part that can be purchased.
And looking for V-Link information (where to buy and costs).
John
