- Oct 31, 2021
- 22
- Plaster
- Jandy Aquapure 1400
Hi Everyone,
I am a new pool owner. My pool is about 4-5 years old. It is 16000 gal saltwater pool located in Texas.
Basically I found the pool return feeds water to 5 nozzles, one placed at the bottom of the spa, and the other 4 placed around the main pool. Today I noticed very small bubble coming from 3 of the nozzles that are closest to the pump(the one located in the spa and two in the main pool), The bubbles are very small, but they do appear consistently with the pump operating at normal speed.( filter pressure 20psi, pump 2500 rpm)
My questions are:
1. Is this a serious issue? Is it possible that I have underground pipe leaks?
2. I googled and found a lot of posts say it indicates leaking at pump suction side, could it be seal leakage? but if there is seal leakage at the pump or pipe union, why the bubble only shows up in 3 out of 5 nozzles?
3. How to troubleshoot it?
Thank you very much,
Joshua
My questions are:
Joshua
