- Oct 10, 2018
- 29
- Vinyl
- Pentair Intellichlor IC-40
Ok, so let me see if I can articulate this. We finished our pool build at the beginning of December 2018. During the dig our sewer line was found and hit by the backhoe digging the deep end of the diving pool. We were given the option to repair it as it lays under the pool and dig it deeper or to reroute it around the pool by adding three 90 degree bends. On the advice of the excavation company we went deep and under the pool. They had to trench the wall of the pool to replace the pipe they hit and we were back on track within 24 hours. No problem. Pool finished and we stared at it covered all winter. We opened the pool 3 days ago and as the water has started clearing up we discovered that the trench line is visible on the bottom of the pool where the vermiculite was laid. It goes from the steel wall to the bottom flat (about 4 feet) is about a foot wide and maybe 8 inches deep. It looks exactly like the trench did before it was back filled with dirt. The wall is intact but of course it steel backed by concrete with deck over the top. It appears that the ground was not packed in prior to the vermiculite application and now has caved in. Pool builder is coming by in the morning to check it out. Questions : anyone ever seen or dealt with this? Who should be responsible for the repair? Ugh. We were *this* close to the dream and I'm afraid of it turning into a nightmare. Thanks for listening.
