Our family is new to pool ownership and we're struggling to figure it all out. We've had an all out war with algae over the past few weeks but I think my wife finally won that one. Now we seem to be battling sunlight and pump run times.
We’re burning through chlorine pretty quickly, although we’re currently at 3 ppm and we’ve been using 73% powered calcium hypochlorite on the recommendation of the local pool store to keep the levels in range; that said, we think the algae and direct sunlight has been burning it off pretty quickly. Our other chemicals are in range with the Cyanuric Acid currently a little high at 55 ppm according to the test we ran at the pool store today.
We live in North Texas where it’s been pretty hot and our pool has direct sunlight on it for just about the entire day. We have a 16,000 gallon chloriene pebletech pool with a variable speed pump, an inline chlorinator and a system that is supposed to reduce the need for chemicals with a UV Light and Oxygenator but the algae would tell me those two upcharges were pretty useless.
We’ve been running the pump schedule our pool builder told us to use in the summer: 7:00 am - 11:00 am @ 90%, 11:00 am - 3:00 pm @ 75% and 3:00 pm - 7:00 pm @ 50% - does this sound correct? We want to make sure we’re maximizing when we add the chemicals, how many/how much we use and run the pump at the optimal times based on adding chemicals, using the pool, the direct sunlight and the electricity use.
Thank you in advance!
