variable or single speed pump for 30,000 gal inground?
JoanC
196
Rome, GA
Good Saturday to all!
My single speed 1.5hp pump motor died yesterday. It was making awful sounds, scratchy/screeching sounds and not moving the water through the jets.
There was a big puddle under the pump and motor too.
Motor had a whine now and then since last year. I thought we were in trouble then.
Anyway, pool store can't come out till sometime next week so I'm testing my sparkling water and stirring chlorine untell they get here.
Haven't had to shock in years! This is killing me with algae worry!
I don't know if they're going to say new pump and motor or fix seals or whatever on the pump and replace the motor.
Whichever the case, do I get another single speed, two speed or variable speed motor?
The single speed I have, a centurian, has lasted for only 3 years running average of 6 hours per day all seasons.
The previous single speed lasted 6 running 24/7 and cost less. However our power usage dropped to half.
Will a two speed be better and cost less to operate?
Will a variable be better and cost enough less to pay for the increased price?
What brand do you suggest?
If I have to replace pump too, I prefer Hayward.
Thank you!
Joan
cowboycasey
8,590
Southern OK
CircuPool SJ-40
This one is easy :)
Get a 1.65 hp V Green VS motor to replace the dead one.. Also get a new rebuild kit for your pump along with a salt or SCS seal to replace the dead one...
Call inyo to make sure you get the correct motor... best 400 bucks ever Variable Speed Pool Pump Motors - INYOPools.com :)
  • Use-The-Right-Seal-For-Your-Pool-and-Spa-Pumps.pdf
Reactions: JoanC
JoanC
196
Rome, GA
This one is easy :)
I’m okay with $400. The pool store will probably want more. Is there a brand at inyo I should look for or are they all inyo’s brand?
