What are the readings of the water temperature and the solar temperature?
If the solar temperature isn't about 5 degrees higher than the water temperature, the solar won't activate.
Solar temperature differential start up and run settings.
Start: Set the temperature differential to start heating from 3° to 9°. For example, if “Start” is set to 3°, this ensures that the temperature has to deviate by 3° at least to the specified set point temperature (in the Heat menu, on page 25) before it switches on.
Once the solar comes on it will start converging as it is heating. This ensures that it will not continually be switching on and off.
