Vacuum solutions
Belluca
16
Matawan nj
I’m wondering if someone may have a suggestion for me. I have a decent amount of algae settled at the bottom of my pool but since I have poor suction from my skimmer I can’t use my robot vacuum to clean it. I’ve called 5 pool companies already but I can’t find anyone who’s willing to clean the pool for me. 3 of the companies didn’t even return my call. My only option is a battery powered vacuum (essentially a dust buster for the pool) but not only will that take forever, but the vacuum also blows out the sides which clouds up the debris and I can’t see what I’m cleaning, if anything. Does anyone have any suggestions for me? Maybe I can rent a good electric vacuum that uses a separate power source? I live in central NJ.
Thank you.
YippeeSkippy
17,387
Evans, Georgia
-Algae..... you have a chemistry problem, I take it. What's the plan to fix that?
-Robots don't use skimmers. It sounds to me like you have pressure side vac of some sort. Does it help to alter valves to increase the suction on the skimmer?
-The best thing for you to do while you work on the algae chemistry problems is to brush, brush, brush and get that up into circulation so that your filter might trap some.
Maddie :flower:
Reactions: Tbone2087
Belluca
16
Matawan nj
Also, there’s air bubbles coming into the pool from both jets. Does this mean there’s a leak somewhere? And would this be why I’m getting no suction from one skimmer?
YippeeSkippy
17,387
Evans, Georgia
Yes, it could certainly be a leak, and sure it might be the cause of the weak suction.
What are you doing to kill the algae? Even though you're finding dead algae, there is still live algae in the water if you haven't done a SLAM process to slay that beast.
SLAM Process
DLip
38
Jupiter, FL
Hayward Aqua Rite (T-9)
Do you have enough suction at the skimmer to vacuum the old fashioned manual way? That is going to be your cheapest option- the vac head attachments are generally around $30
As mentioned above need to fix your chemistry
Belluca
16
Matawan nj
SLAM Process
I did a cycle of shock and some “green to clean” from Leslie’s pools. That cleared up the algae and left me with plenty of sand-like stuff on the bottom of the pool. It’s cleared up considerably but still cloudy. More importantly i noticed water leaking from under the motor. Right where it attaches to the filter basket section. I just replaced the motor so i can assume that it wasn’t attached properly. Is there any solution you can think of besides removing and replacing the motor? I have no electrical skills and I’m worried I’ll make it worse if i remove the motor. I wish we could attach videos so i could show you the leak Thank you
Tbone2087
23
Memphis /Tennessee
If motor is new it probably does not need replacing. If a company installed the replacement motor recently, contact them and tell them the situation. May just need a new rubber seal or silicone type sealant where motor is bolted to basket section. Also, check the seal on your strainer basket lid for small cracks.
