Vacuum attracted to my steps???
Rocket J Squirrel
391
Alamo, CA
That's not a vacuum. That's a pressure-side cleaner. Vacuums suck water into the filter or skimmer.
You can try adjusting the jet in the back of the Polaris. Given the way it gets stuck, perhaps pointing the jet a little to the right (as viewed from behind) will help it turn right and get out of that corner.
atttech-2
1,184
Central Valley CA
Agree with Squirrel, rotate the jet in the back 180 degrees that will make it point in the opposite direction and may fix the problem. You can also reduce the amount of flow to the tail by adjusting the set screw near the base of the tail. That will give a little more speed and toque to the wheels and may help it climb the step instead of getting stuck. Last thing you can try is if you have a VS pump increase the rpm it uses while the cleaner is on, again will add some speed and torque and help the cleaner climb a bit better.
JaySav
77
Memphis, TN
Thank you guys for all the tips, wasn’t aware of any of that. Didn’t know it wasn’t a vacuum either. Just got the house with the pool so I’m learning daily. I ordered new tires because I can see the wheel still turning but the tire slipping so figured maybe the tires were a little wore out. I’ll try adjusting it also. Thanks
Rocket J Squirrel
391
Alamo, CA
Another possibility is that your back-up valve isn't working. That's the big white triangular thing partway down the hose. It contains a clockwork mechanism which, every few minutes, should pull the 280 backwards, precisely in order to get out of places it may be stuck in.
If you don't have the manual, you can get it here.
JaySav
77
Memphis, TN
Speaking of the reverse jet, it seems to not be working properly. It is constantly spraying which doesn’t let the vac move around. It just started happening. Do you just put a new reverse valve on or is there a fix for it?
Thread starter Other Threads of Interest Forum Replies Date
K Pumps, Filters, and Plumbing 2
C Pumps, Filters, and Plumbing 6
F Above Ground Pools 6
