Vacuum accident by idiot
Winterhater
20
Minnesota
I seem to be the problem child around here mostly because I know nothing. I tried vacuuming my pool this afternoon and the vacuum head came loose and the hose ended up out of the pool and sucked in some air. I turned off my pump right away, but lost prime. I have a sand filter, chlorine pool, pentaire variable pump. After some effort and air bubbles in the pump I was able to get the pump back online. However, my kids were swimming etc so after awhile I turned the pump off. It lost prime again so I went back to prime again. The pump was getting a lot of air before it finally primed. I think the weir was stuck so I had run over to the skimmer to look at it and it was sucking water like a toilet bowl. It did fill and seems fine . My question is do you think I still have air in the system after this happened causing my pump to get too hot? I am not getting air bubbles in the returns and skimmers seem to be functioning, no air bubbles in the pump. I just don’t want to run my pump if anyone thinks there is a chance if air in the system and could burn out the pump. Ugh
markayash
4,185
Atlanta Ga
Probably just had air stuck in the lines. Shouldn’t hurt anything.
MirGSS
97
Okemos MI
2 quick comments: I always re-fill the pump filter with water if I've had the pump off for more than a few minutes.
Also if your skimmer was sucking like a toilet bowl, either yes your weir was stuck, or the water level in the pool was too low.
Welcome to your pool adventure!
Reactions: Winterhater
