Utility pad plumbing diagram
SSharp
53
Nebraska
Looking for feedback on the attached plumbing diagram. Pool has 2 skimmers, main drain, 4 returns and 1 set of deck jets. I currently have drawn the below listing of valves.
  • 2 each: Jandy Check Valve, 2" - 2.5" (CPVC)
  • 1 each: Jandy 3-Way Never Lube Valve, 2" - 2.5" (CPVC)
  • 8 each: Jandy 2-Way Never Lube Valve, 2" - 2.5" (CPVC)
Jimrahbe
17,965
Bedford, TX
S,
What you show works for me..
I am not sure why you have a check valve in the middle of the heater by pass???
I would not add a valve for each of your individual pool returns.. I would add one valve for all of them.
If you have more than one deck jet, it would be important to (somewhere) have an individual valve for each jet so you can have a uniform height.
drglanton
94
Atlanta
Great! What program did you use to design your sketch?
