Using muriatic acid in vinyl pool? Yes or no?
Coilshot
3
Florida
I have an 18' round AG pool. I installed a new SWG and pump. Yes I know what I got is over kill for the pool size. But we'll be getting a bigger pool later. The info on the new SWG Blue works BLSC20-T says not to use dry acid to reduce PH. Pool store says not to use MA because it will damage the vinyl...? Then how do I lower my PH if I cant use either?
Test samples were 12 hours apart.
Pool store test: Morning
FC – 3
CC –0
PH–7.8
TA –120
CH – 150
CYA –50
My Test: eveing
FC – 2.5
CC –0
PH–8
TA –110
CH – 150
CYA –50
mknauss
29,588
Laughlin, NV
Welcome to the forum!
Use muriatic acid. No issue. Pour it in slowly at the return flow from the pump. Brush the area to mix it in well, if necessary.
Looks like you need to raise your CYA a bit and keep a higher FC. Otherwise looks good.
I suggest you read ABC's of Pool Water Chemistry.
Richard320
23,592
San Dimas, CA (LA County)
Pool stores prefer to sell dry acid. It comes in nice plastic canisters and stacks neatly on the shelves, like all the other chemicals. Muriatic Acid has to be handled carefully so it doesn't spill and doesn't vent all over something. That's why they push dry acid.
Coilshot
3
Florida
Yup, planning on adding 1 pound CYA. And increasing SWG %. Thanks for the info, was pretty sure it was something like that. I'll be adding MA to my shopping list.
IceShadow
2,177
Milwaukee, WI
Plus you can buy MA at any hardware store.
