Used Metal Magic to remove rusty well water...how to get water to clear?
Lisaheidinger
61
Port St. Lucie Florida
DAC9DB86-5C49-4B55-A982-5D5664C55312.jpegI put my hose in to refill evaporated water....i live is south florida and we have hard iron water. my hose is post water softener...however my water softener failed and i ended up with rusty well water in my pool. I could see a very bad orange tint to the whole pool. I researched forums and chose to use metal magic. I followed instructions and after several day the orange color cleared up. cloudy water remained...i kept running pump and cleaning filter.. the water cleared but i had drifts of white powder looking substance on the bottom. I vacuumed and then cleaned filter....water was cloudy again. Drifts came back but were smaller. Water again cleared up and just now when i vacuumed because we had several windy days so I had some dust and dirt in the bottom the water again clouded up because while i have no visible drifts on bottom i still have something?
What else should i be doing? It has been 4 weeks since i had the well water accident....
my pool is 12000 gallons gunnite , chlorine generator
lisa
i have good
test kit and all my numbers are in range
lisa
mknauss
22,961
Laughlin, NV
With those results we would not think you would have scale or calcium carbonate able to form. I assume the water temperature is below 70F. Do you use Cal Hypo?
I am not an expert on Metal Magic.
I would lower the pH to reduce the TA - but - with iron you do not want to lower pH as it will precipitate the iron.
Lisaheidinger
61
Temp is 71. ..i do-not use cal hypo...
I see the tA is a liitle hight...i usually keep it at 80....the white drifts showed up right after i used the metal magic...it appears that the particles are too small to be filtered all out...it is very fine.i
mknauss
22,961
Laughlin, NV
Can you get a sample of the material? If you can, put some in a plastic container and put a drop of acid on it. See what the reaction is.
Lisaheidinger
61
I recently completed a SLAM.... found some algae at the bottom of pool under the main drain. I brushed it out and then slammed.....that was late October. Pool has been clean and clear since then until the fill to replaced the evaporated water went wrong..
