Hello,
First time poster here, but I've been reading the valuable advice everyone posts here for quite a while.
Our 20 year old pool equipment has slowly been dying. Upgraded the pump to an Intelliflo VSF and the heater to a MasterTemp 400 HD.
Now I've come to realize that we don't have a good way to make sure the heater turns off before the pump. Can have a timer switch to control the heater, and try and make sure it's within the hours the pump runs... but the timer can get out of sync. And, we often use the pool outside of the regular pump schedule (have to love the egg timer feature on the Intelliflo), but this means we'll have to remember to turn off the heater ahead of time.
Honestly, we like to leave the heater on during fri-sun, and just know the pool will be heated. This seems like a no-go without having some way to turn off the heater 15 mins or so ahead of the pump, right?
So, I feel like my hand is forced, and it's time to add IntelliCenter. Also seems like a good time to go switch to a SWG.
We have a 20,000 gallon pool, so I am thinking of IntelliCenter with IC40 or IC60 (sounds like everyone would recommend IC60). But, I'm pretty confused by the options. We have a home automation system I'd like to integrate with, which is why I'm leaning towards IntelliCenter.
We have a spa that spills over into the pool. We have to manually change the valves whenever we want to change the water to divert to the spa only.
We don't have much else for features. Just a light in the pool, a light in the spa, and a small fountain that shoots water into the pool when another valve is turned. We do plan on adding some landscaping lighting some day, so maybe that would run through IntelliCenter, too.
Any advice on which IntelliCenter system to get? Also, I assume we need to change out our old metal filter for the SWG, get some actuators for the valves, and I'm not sure what other components for adding a SWG.
(Honestly, I'd probably delay on all this other stuff, if we could just get the heater working well with the pump right now... but I'm sure I'll be happier once we get automated and switch to a SWG.)
Thanks for any input you might have!
