My stone on the spa spillway needs to be re-done. Water is seeping under the spillway stone when it is on. Here is my plan and looking for advice:
1. Empty spa and float a tarp over the pool, attached to the pool tile with stucco tape to keep debris out of water.
2. Remove stone, chisel and remove all grout, grind down previous mortar bed (how far should I grind, chip, chisel this down?)
3. Inspect spa shell for cracks.
4. Build the spillover area back up with hydraulic cement or a waterproof mortar if necessary once old mortar is removed.
5. Cut 1/8 inch grooves in new mortar bed and in the bottom of the stone
6. Apply Hydra Ban to the new mortar bed.
7. Use 254 Platinum Thinset to reset the spillover stone.
8. Use an Epoxy grout to grout in the stone.
8. Cut a 1/4 groove underneath the stone spillover to break the surface water tension when spillover is running.
Am I missing any steps? Product choices are acceptable? Masonry Advice? This problem seems to occur with a tons of pools so I would like to document each step of this process and have a successful outcome for others to review later on.
I did an owner/build on this pool 10 years ago and did a lot of the work myself. (Not the stone though). I am very familiar with the pool but I want to make sure this is done right so I don't get spillway water leaking underneath/behind the spillway stone.
