Current Test Results:
FC - 12
CC 0.5
CH - 650
Alkalinity - 160
pH - 7.5
CYA just over 30
Background: Our pool was new last fall, closed it crystal clear. Cover blew off. We are surrounded by maple trees. This spring it was a fishy swamp. I dug out probably 10 or so 5 gallon buckets of maple leaves and pine needles. End of March I started what I'm calling a blind SLAM. Didn't have the test kit yet, so just shocked the heck (Gallons and gallons of liquid chlorine). The regular up to 5ppm chlorine test was always dark dark orange. I had no CYA in the pool at the time. (I know this because once I got the test kit, I had none) so in theory it should have been way more chlorine than needed to SLAM. Fast forward a week and it was no longer a swamp, just very cloudy blue and high CC. I kept the chlorine very high and filtered/backwash/vacuum/scrub daily. I was really happy with that progress! That would have been End of march into the first week of April.
Test came and I continued to SLAM. I got very little out when vacuuming, but it was still very cloudy (can't see past 1st step). So, I continued through April basically vacuuming, bleach, scrub. I got frustrated after weeks of no progress so last weekend I used flocculant. (I know, I know) Nothing happened, it didn't work. Got yelled at for it here (Lol). I couldn't see the bottom but I vacuumed to waste as much as I could. I also did a deep clean on the sand filter. Lots of dirty water came out. That was Sunday/Monday. Filter doesn't seem to be affected from the Floc so i think I got most of it out. I do shut the filter off from time to time and let things settle and vacuum, still no solids except a few small pieces in the skimmer.
I know the process can take awhile, but should it take this long with my numbers pretty decent? I've been getting the above results for the last week and a half. I thought I started this process only a few weeks ago, but I actually started March 29th so it's been a month and a half of shocking.
Should I be concerned about phosphates? I've read that leaves can raise it. With the amount of tree junk that was in my pool plus what I deal with daily (Whirly birds galore, but skimmer takes care of them) could this be an issue? I imagine my phosphate level is quite high, I don't have a test for it though. I read here it's not really a number to worry about?
Any thoughts on this?
FC - 12
CC 0.5
CH - 650
Alkalinity - 160
pH - 7.5
CYA just over 30
