I am a Brand new pool owner. Just purchased a home with an ungrounds pool. I can’t say I’m completely excited about it. I can say that the local pool store is getting really sick of my constant questions. Anyways, the “pool guy” that came over said the motor needs replacing. It finally turnEd over after he cranked some rust off of some bolts, however it does run particularly loud. The noise seems to come from the impeller which I’m confused if that is actually the pump or not?
When I google the motor ID (USQ1072) a replacement seems fairly cheap ($150ish)
Is this model old? I’d like to replace and or update the whole scene (will require cutting pvc)
Does anyone have a suggestion on what to replace, what’s worth the investment and is less than $1k to accomplish.
Also I believe air is getting into the trap near the pump so that also might need replacement.
Any help would be appreciated!
Thanks!
Thanks!
