Hi Everyone,
As a new pool owner - in ground plaster approx 27K gallons, completed construction and opened last week of March 2021 - I've been learning so much from this forum. Thus far everything is going well. Using Pool Math, testing w/ Taylor kit, etc.
While my numbers appear to be lining up well with the thresholds in Pool Math and described on this site/forum, one lingering issue I'm seeing is my pH continually drifting up. Every 4 days or so I find myself adding acid to bring pH back in line. I had to add acid today after taking the numbers and finding pH had again drifted up to 8 or slightly above. My numbers for today were:
FC - 4.2
pH - 8+
CC - 0
TA - 90
CH - 280
CYA - 35
My question is related to TA and what I've read on this forum. If I understand correctly, my TA is what should be holding my pH relatively in place. This site says too low and it will move around wildly, too high and it will drift upwards. However, my TA is typically testing at 80, which is in threshold based on Pool Math and recommendations I've read here. So, is TA of 80/90 so high as to cause my pH to drift up? Or, since this is a new pool and plaster, is this drifting pH to be expected and I should just give it a bit more time to stabilize? Is there perhaps something else going on here?
Any help for a newbie appreciated, and thanks!
FC - 4.2
pH - 8+
CC - 0
TA - 90
CH - 280
CYA - 35
