It started out as just a lot of air bubbles from the return jets. But after being away for a few days I returned to a very green pool. The filter was not moving much water, many air bubbles and the pump basket was probably half full. I couldn't locate the air leak and get the water moving so broke down and called a pool repair company. They pressure tested the line and said the pressure didn't hold (went to zero). They recommend digging up the old line and putting in a new line. They cut the suction line at the pump and placed a temporary line directly into the pool bypassing the skimmer.
My question is: The skimmer has been isolated from the pump for about 5 days, but there is still water in the skimmer and the line. If there was an underground leak wouldn't the skimmer and line lose water? Or wouldn't I be losing water from the pool? Is there another test that can be done to confirm the line has to be replaced?
FYI, I do not have a main drain and the pool only has one skimmer. The second one was sealed off when a different pool service said it was unusable.
Thanks for any advice.
