Under Construction in NJ - filling with water - leaky stairs
cowboycasey
6,832
Southern OK
ummm, there is the hole.. I would think it is a good bet it is leaking from there... not sure how they do installs so I am not sure if this is normal...
mikemikemike13
Active member
Oct 1, 2020
29
New Jersey
That’s what I’m thinking @cowboycasey. Since it’s on both sides I was wondering if there was maybe a reason for putting the small pieces there but I’m thinking they screwed up one side and did the same on the other side since it seems I’m the only customer who inspects their work.
jonnyd91
149
NJ
Hayward Aqua Rite Pro (T-15)
Finally filling with water and looks like I may have more problems. There is a spot under the fiberglass stairs that seems to be leaking.
Think this is a crack in the stairs or did they mess up putting the liner in the track along the bottom?
Anybody know how the PB should address this before backfill?
Do you have a panned out view of these? Its hard to tell what orientation the pics are in conjunction to the stairs themselves
jamjam
474
NY
I can’t make out where you think you see a patch - however, if there is a patch there i suspect that you should have they rip the liner out and put a new one in
jamjam
474
NY
Ideally you would have a new crew do this work and bill the PB but we know we don’t live in a perfect world
mikemikemike13
Active member
Oct 1, 2020
29
New Jersey
Here are some panned out photos. The patches are in the bottom corners of the stair track. The leak is on the left side only (looking from behind the stairs)
jamjam
474
NY
It is weird - the stair gasket and trim, as far as i know, goes in over the liner then the opening is cut along the inside of the trim - for there to be patches there they either re-did it or anticipated issues? What part of the scrap liner were the patches cut from - that might tell you what point in time the patches were cut
mikemikemike13
Active member
Oct 1, 2020
29
New Jersey
It was cut from the big piece of scrap from the stairs. I wasn’t here when they cut the liner. Ill have to review my cameras and see how they did it.
jonnyd91
149
NJ
I wouldnt think from where that water is coming from there was a crack in the stairs, look like its most definitely an issue with the liner install. I would stop filling the pool and get them out there asap, chances are that you will have to drain that water right back out for them to fix it.
mikemikemike13
Active member
Oct 1, 2020
29
New Jersey
Looks like they cut the patches before installing the track and cutting the liner. Not sure why. However, they did all that without any water in the pool.
mikemikemike13
Active member
Oct 1, 2020
29
New Jersey
Yes, I stopped filling it as soon as I noticed. Is it possible for them to fix it properly without a new liner? Seems like if they have to remove it from the track or drain the pool completely it’s going to be shot.
jonnyd91
149
NJ
I would push for a new line mostly because you are paying a ton of money for this one with a patch in it.
mikemikemike13
Active member
Oct 1, 2020
29
New Jersey
So I sent a pretty aggressive email this morning demanding a new liner as I didn’t agree to a patched one. They immediately responded (which has not been the case so far) and said they would have the installer out there to see what’s going on. I told them the owner should come as well as the original installer is not going to acknowledge his own mistakes and that I need something in writing explaining why the patches were used. The owner responded that they are not patched but just reinforcement pieces. I’m not a PB so I don’t know if that’s true or not.
I’m going to email Latham and explain how it was installed with the “reinforcement patches” and see if that will affect the warranty at all. Contract also has a five year labor warranty on the liner but I can’t see myself ever calling this company again once pool is finished.
jonnyd91
149
NJ
Yeah, thats a tough one. It sucks to not be able to count on a warranty for a brand new expensive pool. I would let them try to diagnose first. Maybe its just a bad gasket seating and all will be well. Do you happen to know exactly where they put that small square piece of liner? I thought they patched the actual liner itself somewhere.
Since it looks like its leaking from 2 spots maybe it just is a faulty gasket or not so good install. I know the liners are pretty Dang tough, I watched them stretch mine pretty good.
jamjam
474
NY
my suggestion is to arm yourself with as much info as possible but take a deep breath and let them come out and take a look. Don't put them on the defensive too much - when they are there -especially if the owner comes - just be calm a conversational. Don't let your mind jump to the worst case scenario. It is possible that they do double up the liner to reenforce it (but i am not sure why that would be needed). You just want a non leaking liner and one that is installed and will perform as expected for its useful life, and that is the point you want to make to these guys.
jimmythegreek
In The Industry
Aug 10, 2017
3,699
Morris Cnty NJ
I've seen this done by others. They add a layer over that bottom corner for extra support. Often used when dry setting a liner. The best way is to vacuum and start filling the pool. Then come back when liner reaches just under stairs then cut them in. That is a wet set. It only really happens when filling with a truck or replacement liner with a bladder system.
I have seen 2 stairs in my time leak from bad factory gasket track. Under the groove strip there is a gasket sealing it to the stairs. The liner is then sandwiched with the opposing groove and screws, then iner cut, and the finish trim installed. The top groove needs to seal completely edge to edge. Looks a little short in your pic. That can do it. The other thing is they used way too little concrete under the stairs in my eyes. I fill up to 3rd step. It's so hard to compact under there. Nothing worst than hollow steps
