TX Freeze - pool pumps working, water feature pipes busted, Pressure 0
ottc777
6
Katy\tx
hopefully a quick question... would the water feature pipes being cracked (completely apart) cause the main filter pressure to read 0 (waterfeature pump is off)?
pool pump primed normal and ran normal. water circulating. there are no leaks that I could see. pool ran for over 3 hrs and no water around the equipment pad.
SwimAustin
165
No. The water feature is probably on a separate branch (PVC), so if the rest of the system is running fine and the gauge is stuck at zero, it sounds like your gauge went bad from the freeze. It's common. You can get nice glycerin-filled gauges HERE.
I love the glycerin-filled gauges. They last so much longer. Mine didn't survive mid 20's last week. I only know that because the needle is pointed straight down.
