Two Speed Timer for 110V Motor
ATMINSIDE
9
Harrisburg, NC
Pentair Intellichlor IC-60
Hello all, I have a Century B2981 pump motor and I'm looking to hook up a two speed timer. I have 120V 20A going to the motor from a single breaker. It seems like if I had 220V I would be ok because I could use a T106R timer, but I can't find the 110V equivalent and the timer motor in the T106R timer appears to need 220V to function.
Does anyone have any ideas here on what I could use for a 110V motor timer?
Thanks in advance!
ATMINSIDE
9
Harrisburg, NC
ATMINSIDE
9
Harrisburg, NC
ajw22
29,068
Northern NJ
Thanks for the info! One other thought, when the pump is on low do I need to turn my chlorinator off or should it be fine leaving it on 24/7 and just have it say low flow when the pump is on low?
No problem with the IC60 saying low flow when the pump is in low. It will not be generating any chlorine.
