My hubs left for a couple weeks - far away fishing, of all the nerve, and out of contact. Before he left, I cleaned (hosed down with the hose sprayer) the filter cartridge to get the hang of it under his tutelage, and today I've done it by myself.
It's a Hayward C48D43A04 pump. I got everything unlatched, cleared the filter basket and then sprayed down the cartridge, put it all back together........but it won't 'prime' that I can tell.
my steps too restart............
replaced the drain plug
set the cover back in place
tightened the lock ring till it latched
replaced the cover over the filter basket and tightened.
opened the air valve
turned on the pump.
At this point, I think within several seconds the water should fill the filter basket and start rushing out of the air valve, at which time, I close the air valve and go on about my business. However, after about 30 seconds, I'm not seeing any water filling the filter basket, so I shut the pump off, afraid I'm gonna burn it up if no water is coming through. have done this several times. I released the drain cover from the filter cartridge tub and some water did come out, so I think it's filling but I'm afraid of letting that pump run for too long - it doesn't seem like it should take very long before I see water. What could I be doing wrong?
this is our 4th year with the pool, so I don't think anything's wrong with the system...just think I've done something wrong. he won't be back in phone contact for 4 days, and home for 6. I hope it's something simple and a duh moment, but I can't see it. I need to get it going before then! ugh!
turned on the pump.
