Starting in early April I have been trying to maintain the pH of my pool between 7.4 and 7.6. On 4/7 it was 8.0 and TA was 110. I added 1.5 quarts of muriatic acid and the pH dropped to 7.4. A week later the pH was up to 7.8 and TA was down to 100. I left it like this for a few weeks and then on 4/27 pH was 8.0 and TA 100. I added 2 quarts of muriatic acid and pH went down to 7.4 by the next day. The following week pH was back to 7.8 to 8.0 and TA was down to 90. This cycle repeated several 2 more times. Current levels are pH 8.0 and TA: 70. Since the TA is now low, I don't understand why the pH is high. I am reluctant to add any more acid since the TA is low. Adding sodium bicarbonate to increase the TA seems wasteful since my past experience tells me that when I add acid to reduce the pH, the TA will eventually lower. Something else seems to be at play. Any ideas?
Pool Info
Type: Plaster
Filter Type: Sand
Heater: None
Sanitizer: Sodium Hypochlorite preferred, Calcium Hypochlorite when preferred not available
Test Kit: Taylor K-2006
Last Test Kit Results 6/6/2020
FC: 2.5
CC: 0.0
pH: 8.0 (acid demand 2 drops to 7.4)
TA: 70
CH: 350
CYA: 40
Temp: 85
Last Pool Store Test Results 6/9/2020
FC: 0.93
TC: 1.1 (CC = 0.17)
pH: 8
TA: 73
CH: 276
CYA: 53
Iron: 0.1
Copper: 0.3
Phosphates: 812
TDS: 1200
Pool Info
Type: Plaster
Filter Type: Sand
Heater: None
FC: 2.5
CC: 0.0
TA: 70
CH: 350
CYA: 40
Temp: 85
FC: 0.93
TC: 1.1 (CC = 0.17)
pH: 8
TA: 73
CH: 276
CYA: 53
Iron: 0.1
Copper: 0.3
Phosphates: 812
TDS: 1200
