Hi, hoping to get some help here.
Our pool company handed over maintenance to us last Friday (3/3/23), and my TF-Pro kit arrived yesterday (3/6/23). When testing my numbers came back as:
FC - 0.5ppm
pH - (very pink) above 8.2
TA - 80
CH - 175ppm
CYA - 60
Our pool is not very large (7961 gallons), and we have a spa. I used the Pool Math app to determine how much chlorine to add - I ended up doing 71oz of 10% Bleach. I waited 30m and tested this again, and FC came out to 5.5ppm (CC was 0). I then added 17oz of 20 Be (31.45%) muriatic acid, waited a couple hours and tested pH again - pH was still very high , above 8.2. I repeated this process and added the same amount (17oz), retested 4 hours later and again pH is still above 8.2
At this point, I'm wondering if I've misread something, or am doing something wrong. I'm not sure why the muriatic acid isn't lowering the pH. As for application, I slowly added the acid in front of the return jet, pump running at 100%.
My guess is I'm supposed to just keep repeating this process, adding about a water bottle worth of muriatic acid until it finally shows that it should be coming down? Any advice is appreciated - brand new pool owner and first time pool maintainer, hoping to educate myself and not screw things up. Thank you.
FC - 0.5ppm
TA - 80
CH - 175ppm
CYA - 60
