Trouble getting bleach
Wiggledog
110
Souderton, PA
Is anyone having trouble getting bleach. My water is clear but I use a gallon a day once the weather starts to warm and getting belach, at a reasonable price, is not easy. Where are you getting it?
Leebo
Admin
10,477
Eastern Ohio
Users are clearly having issues this year finding Liquid Chlorine. While still VERY early, we’ve started to create a new resource for users.
wireform
In The Industry
Aug 15, 2017
2,088
Spring Valley, NY
This by itself would be good reason to go with SWCG then it would be this year and next, next.....you wouldn't need much besides opening day.
setsailsoon
3,867
Stuart/FL
CircuPool RJ-30 Plus
Back when I used liquid chlorine I found by far cheapest solution was bulk refillable containers. Pool stores here refill for about $8 per 2.5 gal jug for ~10%. If you can find a pool store or an industrial chemical supplier that does this it will be your best bet. Of course best bet of all is install a swg yourself and you won't ever need liquid except for when you open. I waited 5 years to convert. If I had it to do over again I would have switched 5 years ago.
Chris
