Hello - I am looking for recommendations on how to clear cloudy water - specifically water that is cloudy when you are under the water. The water is clear when outside the pool (can clearly see the main drain in the deep end of 9'). Here is the result from my latest test (using Taylor K-2006):
FC: 2.5
CC: .5
PH: 7.0
TA: 150
CYA: 35
CH: 250
Water temp: 88 degrees
In-ground pool: 18,000 gal
Located in Indiana
I know my TA is high but not sure if it causing the cloudiness. I have tried a water clarifier with no success. I am regularly backwashing my sand filter. Do I need to shock again or should I lower the TA? PH is recovering from recent lowering to bring TA down from 240.
Thanks in advance!
FC: 2.5
CC: .5
PH: 7.0
TA: 150
CYA: 35
CH: 250
Located in Indiana
Thanks in advance!
